neue Geraete-Firmware v1.9.1 fuer HP25xxC
Verfasst: 11 Aug 2023, 11:08
Seit heute gibt es eine neue Geraete-Firmware v1.9.1 fuer die HP25xxC.
Das Changelog ist recht umfangreich:
Wie ueblich wird auch diese Firmware auf eine SD-Karte (max. 32GB) gepackt und dann in die Konsole gesteckt. Das Update erfolgt dann automatisch.Add support for Russian language
Add an OK shortcut button when entering a Wi-Fi password on the keyboard
Add automatic time zone detection feature, which is enabled by default. It will automatically retrieve the time zone and time when connected to the internet, and the time calibration will occur 5 seconds after successful time zone detection
Add an option to switch between apparent temperature and perceived temperature in the "more" interface, and the corresponding display on the main interface should also switch accordingly
Adjust the minimum upload interval for custom servers from 16 seconds to 8 seconds
Add an AFC (Automatic Frequency Control) switch function in the setup interface, whichis set to OFF by default. Customers can try turning on this feature when encountering unstable RF reception
Support for WN34D temperature sensor with a specific temperature range
Fix the issue where the humidity names are all in German in the ID setup interface
Fix the issue where the indoor multi-channel temperature and humidity data from the WH45sensor are not refreshing on the main interface
Change the wind speed unit from "btf" to "bft"
Modify the Dutch language
