Bresser WiFi Clearview 7in1 Flashing
AndyChafer
Beitrag von AndyChafer »
Hi
The forecast is displaying two flashing rain clouds.
Is the flashing normal or an issue?
Thanks
Hat sich bedankt: 12 mal
Danksagung erhalten: 8 mal
Re: Bresser WiFi Clearview 7in1 Flashing
Beitrag von Rolf »
Hi,
the flashing is an indication of stronger airpressure changes.
Use "Alert" at the back several times and raise the difference value, then the flashing appears less often.
My experience: patience is required, the flashing stops after the next pressure change, up or down.
Mit Grüßen,
