erste Erfahrungen mit dem LDS01/WH54 als Schneehoehenmesser
Danksagung erhalten: 10 mal
Re: erste Erfahrungen mit dem LDS01/WH54 als Schneehoehenmesser
#31
Beitrag von Mike97 »
Hier noch eine kleine Info am Rande: Beim im CMX-Forum nachstöbern habe ich eine Info bezüglich Diagramm für den LDS in CMX gefunden. Es soll laut den Changelogs der Betas zu CMX 4.7.0 ein Chart für den LDS01 hinzugefügt werden.
Zitat aus den Changelogs:
Adds LASER depth to the Dashboard Recent Charts, Recent Select-a-Chart, and Select-a-Period
Adds LASER depth to the default web site Trends and Select-a-graph charts
Wetterchen
Hat sich bedankt: 54 mal
Danksagung erhalten: 8 mal
#32
Beitrag von Wetterchen »
Von Ecowitt gibst für Käufer der LDS01 Version eine Info Mail
Off-topic
Dear Customer,
Thank you for using Ecowitt LDS01.
We have observed that when the device is used in strong wind and heavy snowfall conditions, wind blown snow may enter the device housing.
Under low temperatures, this can lead to frost forming on the laser optical surface, which may temporarily affect measurement stability.
The device's internal heating is intentionally controlled to balance performance across different temperature conditions and to avoid overheating.
As a result, in extreme blizzard conditions, optical frosting cannot always be completely prevented by heating alone.
Based on this usage scenario, we provide an optional 3D-printable protective cover file for your use, should you need it, designed to help reduce direct snow ingress into the device in heavy snow environments.
https://github.com/Ecowitt/Blueprint_Sharing
The protective cover is not required for normal operation.
It is recommended only for areas with frequent blizzards or strong winds, where it can help improve measurement stability.
If you have any questions, please feel free to contact us.
Thank you for your understanding and support.
Best regards,
Ecowitt Support Team
Danksagung erhalten: 534 mal
#33
Wetterchen hat geschrieben: 21 Jan 2026, 11:55 Von Ecowitt gibst für Käufer der LDS01 Version eine Info Mail
Habe den Druck bereits beauftragt. Leider ist mein Sohn erst naechste Woche wieder in der Schule ...
Danksagung erhalten: 680 mal
#34
:o - ich wusste gar nicht, dass es in Brandenburg so viele Blizzards gibt ...
#35
Off-topic
Brandenburg ist einfach irre!
Blizzards gibt es! Gefuehlt auch immer mehr! Kuerzlich erst wurde wieder einer angekuendigt.
Und Woelfe!
Sogar Polarlichter und andere Himmelserscheinungen!
Und manch einer meint, hier sogar den Yeti schon gesehen zu haben ...
Ich will jedenfalls auf alles vorbereitet sein ...
#36
olicat hat geschrieben: 21 Jan 2026, 19:21 Hi!
Off-topic
Und Woelfe!
Das wäre doch noch ein Sensorwunsch - Bewegungsmelder mit Objektidentifizierung, ggf. als Kombisensor :mrgreen:
Auch für verschieden hohe Montage und Ausstattung entsprechend der Bewegungszonen
LDS-007 ??
Human,
Tiere:
- Feliformia - Haus-, Wildkatze und Luchs
- Caniformia - Rassendetektion (--> Lupus lupus)
- Reptilien
- Vögel
#37
Mal eine Frage an andere Besitzer vom LDS01:
Ist bei euch auch eine Temperaturdifferenz aufgetaucht wenn es höhere Temperaturunterschiede am Tag gibt oder nicht? Ich habe langsam wirklich den verdacht das der Sensor da ein nicht bedachtes Problem mit Wärmeausdehnung des Kunststoffes hat, denn bis um 2cm am Tag ist durch Wärmeausdehnung der Befestigung (Holz) oder des Bodens eigentlich nicht zu erklären.
Ein Diagramm, wie das dann aussieht habe ich ja vor einiger Zeit schon eingestellt:
Die rote Linie beim Air-Diagramm ist die Nulllinie von Depht.
Es ist so tatsächlich etwas schwierig zu sagen dann wenn Schnee langsam taut was die höchste Höhe des Tages ist (nehme nicht den DWD-typischen 7Uhr Wert, weil die Zeit von Messstäben nun mal vorbei ist und die Schneedecke zu viel Schwanken kann in 24h), da in der Nacht mehr Schnee als als eigentlich liegt angezeigt wird und wenn der Sensor sich ausdehnt am Tage weniger angezeigt wird.
Die Schwankungen werden auch erst bei starken Höhenänderungen unerheblich, was im Winter hier in den Bergen meist nur bei Zuwachs passiert, da der Schnee durch die kalten Nächte sehr haltbar ist.
Wenn ihr das nicht beobachtet, wie sieht euer Aufbau aus? Vielleicht ist da ja noch eine Variable, die ich bisher nicht beachtet habe?
#38
Ist das den anderen Besitzern des LDS01 egal? Ich habe weiter lustige Tagesgänge, was irgendwie nichts mit guten Messdaten zu tun hat...
Chorknabe
Hat sich bedankt: 4 mal
Danksagung erhalten: 2 mal
#39
Beitrag von Chorknabe »
Das der LDS01 eine Temperaturdrift hat kann bei mir auch feststellen und es war beim Erscheinen auch schon Thema eines anderen Threads. Bei mir liegt es eher im Bereich von 1 cm, ich messe aber auch nur in 84 cm Höhe. Ich vermute, dass der Abstand vom Boden einen Einfluss auf die Höhe der Amplitude hat.
Für meine Wetteraufzeichnungen sieht man mich morgens um 07.00 Uhr altertümlich mit dem Zollstock durch den Schnee (in Brandenburg also nicht so oft) stapfen. Der LDS01 ist nur die Redundanz des Zollstocks.
Chorknabe
